After a bit more thought.
An earth rod would not make a PME system safe if the incoming Neutral went open circuit. In fact it seems almost impossible to ensure there was no hazard when the incoming Neutral goes open circuit. The type and level of hazard depends on where the Neutral goes open circuit.
Having the CPC at Live potential is not a problem for people inside the equipotential zone (*) but presents a hazard to people outside the zone who come into contact with anything that is bonded to the CPC ( via the MET and main bonds ) Gas Meter, external water taps, external lighting with earthed metal work and electric gates made of metal to name but a few.
(*) since walls cannot be bonded to the MET any wall that is damp and touching the ground would provide the second point of contact for anyone holding an earthed item with exposed it's metal parts at 230 volts above Ground. Probably ( but by no means certain ) the impedance of the wall will be high enough to limit the shock current such that the shock is felt as a severe tingle.
Some one said that cases of the incoming Neutral going open circuit are very rare. Hoe rare are they ? Considering the hazards they create and the damage they have caused ther has to be some information / statistics about them. Metal theft of the Neutral links at sub stations and over head routes have not been that un-common
