Change an Economy 7 socket to a plug socket and add radial circuits
An RCBO in this DB will take up almost all the height available which makes them less easy to fit.
Replace the lot with 1 new consumer unit?!
Perhaps you should check out the RCBO before you comment ?
DS
Oops, I was thinking of the single module versions as I saw one of these boards stuffed with three of them the other day!
Thanks for the reply's guys. Will go with a RCBO and since the tails come from the cellar, it will hopefully be a simple case of replacing the obsolete tails with the new wiring without any drilling needed.
For the RCBO, will it be ok to fit and wire a singular module RCBO if I'm also going to add a 6a mcb and is the procedure that you connect it as normal on the main unit and on the economy 7 unit side, replace the wiring of the tail to the switch.
I assumed it was going to be something like this?
http://m.ebay.co.uk/itm/Crabtree-St...30mA-Trip-BS-EN-61009-61-C13230-/331756475355
