bolier problem
13 Feb 2016
have vorkrea Compaq boiler about 8 years old keep having to top up system to get red light off then have to drain system as it has no leaks every day any idea thanks ps once its on its fine once switch you have to do as above ..
Have to drain water out a radiator as pressure will get to high as you have to top it up every time you want fire it up
Your expansion vessel is either flat or in need of replacement
