    Dismiss Notice
bolier problem
Discussion in 'Plumbing and Central Heating' started by allyboy, 13 Feb 2016.
  1. allyboy
    allyboy
    13 Feb 2016
    2
    Thanks Received:
    Country:
    have vorkrea Compaq boiler about 8 years old keep having to top up system to get red light off then have to drain system as it has no leaks every day any idea thanks ps once its on its fine once switch you have to do as above ..
  2. Echo the husky
    Echo the husky
    25 Mar 2011
    2,476
    Thanks Received:
    326
    Devon
    Country:
    Could you please explain?
  3. Sponsored Links
  4. allyboy
    allyboy
    13 Feb 2016
    2
    Thanks Received:
    Country:
    Have to drain water out a radiator as pressure will get to high as you have to top it up every time you want fire it up
  5. muggles
    muggles
    28 Oct 2005
    13,341
    Thanks Received:
    3,076
    Daventry
    Country:
    Your expansion vessel is either flat or in need of replacement
  6. Sponsored Links
  7. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,094
    Thanks Received:
    1,093
    Norfolk
    Country:
    Interesting use of the English language if I may say.......:ROFLMAO:
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
