Pull switch removal
21 Feb 2012
Essex
Could anybody help please. I want to remove a pull light switch from my spare room.
I have taken a few pics
First pic shows the pull switch wiring. 2 reds and one black. The other black cable has been cut.
and 2 earth going into terminal.
Second pic
Is the wall light switch.
There are 2 cables. 1 Goes through the wall to the switch on the other side however there looks looks like the red cable comes back with earth sleeve on it. The other cable comes down from the ceiling.
Any ideas how I can remove the pull switch would be appreciated
Many thanks
Nik
I don't use the pull switch the cord has been cut. I just use the wall switch as normal.
That wiring has been there since in moved in 2002 so I don't know much about it.
Cutting the cord makes no difference.
Do both switches have to be ON for the light to work?
Can we have pictures of the backs of both switches?
What do you mean cutting the cord makes no difference??
No both switches don't have to be on for the lights to work. they work as normal.
I will take a pic and put it on here
I wonder if, perhaps, it was the only sleeving available and was used to cover some defect in the red insulation?
Or some sort of attempt to try and protect the wire where it comes through the rear knock-out if not already damaged in some way?
But yes, the wiring is terrible.
Possibly - but if that were the case, wouldn't one to expect there to be sleeving on all three conductors (all of which go through the same un-grommeted knock-out), not just one of them?
What is the wiring like in the light fitting a photo would be good. It looks like power has been shoved in one end and taken from the other, but it doesn't look like one cable has been used for the strappers between the 2. I wonder if all the cables end up in the light fitting (or its junction box). It might be easier to convert than it looks. The wiring needs tidying up with rubber grommets and an earth connection to the metal switch etc....
I am trying to decipher your wiring.
The switch isn't altered by cutting the cord.
You may as well say the pull switch works the light; I don't touch the wall switch.
What is normal? The wiring isn't normal.
I'm not sure why your mentioning the cord as I only said in my opening mail the cord had already been cut. (not by me)
You may as well say the pull switch works the light; I don't touch the wall switch. ( why would I say that?)
When I say normal I mean normal IE: you walk into a room and turn the light on or you walk out of a room and turn the light off. that being the case for both rooms.
I'm not sure why your mentioning the cord as I only said in my opening mail the cord had already been cut. (not by me) ... When I say normal I mean normal IE: you walk into a room and turn the light on or you walk out of a room and turn the light off....
The point is that if there is any of the cord left, if you could tell us what happens to the lights when you pull it, that might help us to understand how it has been wired.
... that being the case for both rooms.
What are these 'both rooms'? Does the switch control lights in two rooms at the same time?
