Hi all,
Just joined this forum.
I have a Potterton Suprima boiler (with upgraded PCB) which is causing me trouble...
Just as background info, it has been serviced by BG, pump and electric valves and water tank all replaced recently.
The heat in the rads is very low to a point where i usually turn upstairs off to have a little bit of heat downstairs. BG want to change the whole system, whilst i contacted Potterton who told me i should hang on to my boiler as long as possible as most parts are still available.
Yesterday, my boiler went into lock out (red light flashing every second). I tried to reset it many times and it failed, or ran a little bit and then lockout again, until it eventually seems to start (with green and orange lights flashing at regular intervals) by lowering temp on both boiler and water tank.
Now i suspect one of the issues is that i have a lot of sludge in my system. I tried to vent the rads yesterday as i thought maybe there was air in it and when water started dripping, on one of them it was very black. BG also told me that my system was likely very dirty but they only do power flush with new boiler (of course...)
So my question is, should i attempt using something like Ferndox DS40 or X800?
Also, after using these products, they say "The system must be drained down and flushed several times with fresh water until the water running to drain is clear." (On Ferndox)
Can anyone tell me exactly how the system is drained and flushed several time? Is it just by opening the little drain valve outside my house and let the water run for a bit or is it something more complicated than that? If so, can i do it myself?
