Which, amazingly, is about the rise needed from incoming cold supply to hot tapwater.it will raise the temperature by 180000/4.19/1000=43°
Not allowing for loss of heat to ambient.it will raise the temperature by 180000/4.19/1000=43°
It is ... but hot water cylinders usually contain a lot more than 1 litre of water!! If the immersion is heating N litres, you have to divide that 43° (per minute) by N.Which, amazingly, is about the rise needed from incoming cold supply to hot tapwater.it will raise the temperature by 180000/4.19/1000=43°
That is, indeed, all true - but I thought that people just reading your most recent comment may well not have realised that's what you meant!But that's why I said "an immersion heater warms the water at a rate of about one litre per minute" So a 10-litre washing up bowl might take about ten minutes, and a 50-litre shower might take about 50 minutes, and a hundred-litre bath about 100 minutes.
They still exist (in UK), but are not widely socked (e.g. click here ). As you say, it's just possible that the OP has one of those, but has the 'short' element connected. Alternatively, as has been suggested, he might possibly have a short thermostat in a long element.Is it possible that the immersion heater you fitted was a dual type? There used to be some with two elements, one only heats the top section of the immersion heater and thus only the top part of the water, the other heats the whole length. I think the logic was that you had two switches, one for small amounts of water, the other for the whole lot. It was supposed to save money by not heating excessive amounts of water. I fitted one like that about 4 years ago in Southern Ireland but have not seen one in the UK for a long time.
Or the old "Sink / Bath" changeover switch.Is it possible that the immersion heater you fitted was a dual type? There used to be some with two elements, one only heats the top section of the immersion heater and thus only the top part of the water, the other heats the whole length. I think the logic was that you had two switches, one for small amounts of water, the other for the whole lot. .
Indeed. As I said, that's what I've used as my primary means of water heating for the last few decades. However, I think that virtually all of the heat will go into the water (rather than 'the ceiling'), at least initially, even for a top-entry one!I always believed that a side entry element at the bottom was more efficient at heating the water, as there were fewer losses, as the rising heat from the element was almost all used in heating the water, and not the ceiling instead.
