This idea of what goes in must come out, I would say the heating and cooling of a property is not a straight line, likely to be a curve.
No, not telling - but it should be fairly obvious; you can see who "liked" my bucket post, for example.
But your bucket analogy doesn't hold water (pun intended)
Aquaheat, tell me, in my bucket analogy who do you think would use the most water in the long term?
I know this isn't a perfect anlogy, but it's sufficient for me to work out whether the reader has a basic grasp of the laws of nature.
(BTW in response to one post, I'm not suggesting that water would ever be allowed to flow over the brim of the bucket. The water all comes out of a hole in the bottom.)
With that you assume a constant and both would use the same amount of water but, and I'm only doing this to highlight your analogy, if I only needed that bucket to be full for 8 hours a day so allowed it to be empty for the remaining 16 hours and constantly topped up for that 8 hours who would use more water compared to filling for 24 hours constantly?
I would also estimate that if you have an intelligent thermostat, it would be more efficient with constant heating.
But with an intelligent thermostat they are aware of your away periods and turn the heating off only coming on at a certain time (or geo location) before you return depending on the internal temperature, ambient outside temperature and required set point.
Yes you are right that heating should be set to constantly on if you have an additional timer in conjunction with it but ideally the timer will be removed so that the smart controls can take full control of the system.
Jon
By intelligent thermostat I merely meant one that will apply smoothing to control temperature overshoot and dip.
I think there might be something wrong with your sums.
the bucket will continue to empty outside of heating periods. at 6:30 the bucket is empty and you will need to fill it at 2 gallons per hour and your house will not even be at the required temperature by 8:30.
Try again. Bucket will be empty at 06:30 it fills at a rate of 5 gallons in 30 minutes but loses a gallon a minute so the first half hour takes 1.5 gallons. I can then leave it to empty for the rest of the time till 08:30 as there is still enough water to cover that. It's empty again at 16:00 but I have to fill it twice in a 6 hour period.
As has been mentioned before the bucket analogy doesn't work for heating!!!!
With regards to pressure loss over 14" of bucket how much does that affect the flow rate considering the available head? It's barely negligible. Again your analogy just simply does not work and has no founding in the OPs question!
@endecotp what is your solution or ideas regarding the OPs original question?
@hazetimesfive what is your solution or ideas regarding the OPs original question?
seeing as most of you guys can't even read the graph that he provided your advice and analogies have to be questioned.
If you truly believe that leaving heating on 24/7 is more energy inefficient then i lay down a challenge.
At 22:00 tonight post a photo of your gas meter reading. Leave it on for 24 hours constant with your stat set to 21C and repost another picture at 22:00 tomorrow.
Then time it for 2 hours in the morning and 6 at night to finish at 22:00 and take another picture.
Anyone willing to accept this challenge?
Jon
