- Joined
- 5 Nov 2010
- Messages
- 405
- Reaction score
- 3
- Country
My smoke alarm went off in the kitchen this morning which led me to find the leaks under the bath!
The first leak was coming from the drain hole which was straight forward to fix as it required just a few turns of the bolt on the strainer.
The second leak is coming from the plastic compression nut. Unfortunately I can only tighten it so much before it loosens itself (is that normal?) but still leaks.
I haven't had time to take it apart as I'm off to work but is there something I can buy in my lunch hour (not far from Homebase and similar shops) to remedy this? I'm guessing there's a seal in there that could be replaced, if so are they sold separately and what size do I need? Should I buy a whole unit since I can only tighten it so much?
I've got some Fernox LS-X sealer somewhere, should I use that as well?
Thanks very much and hope you can help.
