Hi there,
We've been having issues with our boiler for a couple of months now. It keeps needing to be reset, so most days it won't come on until we press the reset button. More recently we're having to reset it or turn it off and on completely 3-4 times before it comes on.
The boiler is 14 years old (it's a Potterton Suprima 40L) so it's possible it'll need replacing, but not sure. I've read that it could be a faulty circuit board: http://www.diynot.com/diy/threads/potterton-suprima-40l-lockout-likely-causes.76759
We also have a Santon Premier Plus PP150B water cylinder (unvented) -- not sure if we have anything in the loft, haven't actually checked since moving in.
So I suppose my question is, should we replace the boiler with it being so old, and if so, what type should we get.
We live in a 3-storey semi-detached house with 3 bedrooms. Main bathroom on first floor with a bath/shower, and an en-suite with shower on the top floor. See attached pic for an idea of the size.
A plumber has recommended an Ideal Logic+ 35kw combi boiler, or an Ideal Logic+ Heat 24 Heat Only boiler if we don't want a combi.
I've tried to do as much research as possible about the pros and cons of comb-boilers, but I still can't decide what'd be best. I've had a combi before, and not being able to use two taps at the same time was a bit of a pain, but hot water on demand was good. If the combi mentioned about would be able to push out enough water then I'd probably go with that, but if not then I'd rather keep the cylinder.
That's another thing, is our cylinder actually worth keeping - buying one new is like £700 I think? Would it make more sense to use it and get a conventional boiler?
Also wondered about System boilers -- not clear on how we have a conventional boiler with an unvented cylinder.
Any help/advice would be much appreciated.
Thanks!
Thanks!
