Hi
We have an en-suite upstairs and want to install a new shower. There was one there previously but was old and cracked. We want to install a new slim line shower tray. The previous occupants have the waste pipe above the floor boards because the joists run perpendicular to the waste pipe. I will keep it this way as I don't want to drill hows through all the joists as the shower is some way from the outside wall. So I guess it would be sensible to keep it above the floorboards for easier access and will not weaken all the joists?
What I would like advice on is that we know we will need to raise the shower tray up a bit again for the waste pipe but do I mount the tray on 4 by 2 bits of timber or do I mount it on bricks or something water proof. Do I paint the floor boards below it in a waterproof coating or membrane? Also most do not come with an up stand round the tray for you to tile over these days. Can I get material to run round the tray that I can tile over and create that extra seal?
So questions:
What to tray mount on?
How to waterproof?
Equivalent to an up stand?
Should I use a type of rust proof screw. Are they black?
Kind regards
Rob
So questions:
How to waterproof?
Kind regards
Rob
