- Joined
- 22 Jun 2015
- Messages
- 5
- Reaction score
- 0
- Country
I have a shed base laid using a slablayer (http://www.wickes.co.uk/Blue-Circle-Slablayer-20kg/p/153707) which is part sand part cement, you wet it and it settles after a bit.
Now I've got one slab that is slightly higher than the others (although the shed base is level as a whole) and I feel I need to remove it to re-fit in level with the other slabs, however this slab is positioned right in the middle (please view attached image)
It has settled so it's not a simple pull and it's right in the middle of others so if there's a tool that allows me to remove it to reposition it at a lower level?
thanks
thanks
