Back boiler
25 Dec 2010
Hi.
1950s house. Back boiler removed , not sure if flue removed. How can I tell?! Anyway , in the bedroom where chimney runs though there is an access panel?!? Is this right? Normal?
Paul
Have a look.
If you mean a gas boiler - is the cowl still on the top of the chimney?
If it is the downstairs chimney, again, have a look.
If it is a blocked off bedroom fireplace chimney, it will be completely separate from downstairs fireplace and should have a vent.
Have a look.
Nothing on top of Chimney. Fireplace downstairs is blocked off.
No fireplace upstairs but part of wall is like a panel floor to ceiling in chimney . Why would this be needed? What was the purpose? Access to the chimney?
So, do you mean there used to be a solid fuel back boiler?
If so, there will be no flue pipe, if that's what you meant.
The chimney itself (brickwork) is also called a flue.
Why are you asking?
Never?
You mean ON the chimney.
Decoration?
Yes , there used to be a back boiler but that is removed and it's blocked off downstairs.
I am just curious as to why and what the purpose of this access panel is. There was never a fireplace upstairs. 1950 property.
See attached pic and what you think it is?
Access panel for pipework from back boiler to tank in loft?
Have a look in the loft to see if any pipework or tanks are up there.
