Had to disconnect a no problem, well functioning sanilslim from the wc pan in order to properly seal the adjacent shower screen.
On reconnection, I made the mistake of flushing to check for leads without first switching the macerator back on. I only realised this error when there was sudden load noise coming from the shower waste. However, the overfill alarm didn't activate. I quickly flushed the system and all seemed well.
On further flushing, I noticed that about 5-10 seconds after the motor had stopped its short couple of pumping bursts a gurgling noise was coming from the machine lasting around another 10 seconds, suggesting a progressive intake of air.
In addition, the wash basin feeding into the unit, which had been making no previous sound, now makes a gurgling noise which slowly converts to a slowing popping noise.
It seems there's an air lock somewhere in the macerator., but how can I cure it?
I've tried putting the shower hose pressure down through the waste in case the non return flap on that side of the unit has become misaligned, but this has made no difference.
I should mention that the outflow from the macerator head immediately drops down through a 32mm pipe to the floor void on a 10 metre run to the 110mm stack, avoiding the need for an AAV separate to the unit.
Grateful for any advice.
