Let me also butt in, a 2Kw kettle and a 2Kw grinder are two different things, all appliances that run on electric motors possess so called inductance as opposed to resistance, we call it inductance because its effective resistance changes with the speed of the motor, when not powered up the kettle's resistance remains the same or almost same, as Bernard said, may be change very slightly by insignificant amount as the kettle heats up, an electric motor on the other hand possesses a very low resistance when not powered up, so initially when you first apply power to it, the motor is not running so all that power rushes in many times more in magnitude than when it picks up the speed and starts running at normal designed speed, when it does, it also becomes a generator and starts churning out reverse energy, or power but of opposite polarity, which then opposes the incoming power, but incoming power is always stronger, so it still requires energy to spin yet it will only need a little, so at starting point in time a motor may draw as much as 3 times the normal current it requires but when it has gained acceleration and stabilised it will draw its normal designed current or in other words a 2Kw grinder may suck as much as 6kw for a very brief period, and then settle down to 2 Kw normal running, in fact it will draw much less than its designed rating when it is not under any load, so in fact it may actually draw only 200 watts as there is no loading on it but once you put load on it, that is when it would start to draw more and more current up to its designed rating, and it would continue to exceed its designed power rating if you then subject it to a further loading, so if a grinder was designed to cut a concrete slab 2" thick and it is then using 2kw, but if you now start cutting a 4" slab it will be now subjected to a lot more loading so its speed will drop and its back EMF will reduce so it will not oppose the incoming current as much as it did before hence the grinder may start to draw 3Kw, and since it is designed to tolerate (its internal windings are of a certain size and tolerate a certain amount of heat) so that grinder will eventually cook itself with heat and burn out.
A kettle will draw 2kw irrespective of how much water you put inside, it will just take a little longer when full, and when totally dry it will obviously overheat and burn the element as the element can get red hot and melt.
Bulbs also behave like Inductive loads, but they are not in true sense inductive, because they do not have back emf, but the filament of conventional Tungsten bulbs can draw 10 times as much current on first switching on for a split second , this is the characteristic of tungsten when cold its resistance is very low, or tenth of its normal operating temperature, so once the bulb fully lights up, its resistance will increase, so imagine you have 10 x 100watt bulbs, that is a total load of 1Kw, and on first switch on, they can all start drawing 10 times more, so a load of 10Kw for a split second, but in practice that would not happen since 1.5mm wire would limit inrush current, so no fear of tripping any MCBs.
