Hi
I have just bought my first dishwasher and I am having some trouble with plumbing it in.
The only under counter space for an appliance is the other side of the kitchen, about 3 meters away from the plumbing.
There is however a cupboard the other side of the wall directly behind the dishwasher.
From what I can see I have two options... Run the hoses through the wall and share the plumbing with the washing machine, I think this would involve using a 'T' splitter where the current water intake for the washing machine is, and a 'Y' merger connecting to connect to the waste, sharing with the washing machine.
Or... purchase some hose extensions and run the hoses behind the worktop cupboards to the sink, where there is a vacant intake and waste fitting. The extension would have to be 2.5meters minimum.
I have looked at forum posts for both scenarios, and there seems to be drawbacks for both. Namely; with option 1 the pressure of the water might not be enough to run both appliances at once, and the waste pipe may not be able to handle the extra output. With option 2, people are suggesting that problems may arise from using such long hoses, such as the waste not being able to travel that far in the hose, causing a flood.
I just wanted to see which option people would recommend, and if the drawbacks I have found in my research are actually correct.
I am a novice with plumbing so apologies if I've used any incorrect terms.
FWIW the dishwasher is a Hotpoint Aquarius, I am guessing its about 4-5 years old
Below are 2 crudely created paint pictures to help illustrate my options
Many thanks in advance
Josh
Josh
