For as long as you keep on making your pathetic criticisms, people will argue with you.Again, I refuse to get drawn in a debate or an argument.
Just an update mikefromlondon
Once again, many thanks for all your advice and assistance. It was a nice easy job in the end and no more involved than changing carbon brushes really.
Could you print some of the parts?I use mine for routing and machining parts from plastics and aluminium, at various depths, using a rotary cutter, I wonder if laser can cut to certain required depth into the plastic material and not cut through completely., so i think there is still long way for rotary cutters yet.
