Hi all.
I'm after a bit of info about the wiring in my house which was built in 1970.
In the pics below you can see the black and red cables which come from the meter and go to the junction box on the left. They are fairly heavy looking cables, but then the current is carried to the earth leakage detector by 2 twin cables one of which is a larger diameter than the other. Then it's 2 single cables out the bottom of the ELD which go to the consumer unit.
Does anybody know why there are two twin cables rather than just 2 single cables going from the junction box to the top of the ELD? Also the 2 twin cables look a bit flimsy taking into account they supply the whole house. I'm guessing the two of them together are the equivilant of one heavier cable.
The thick red and black cables that come from the meter to the junction aren't original the electric company fitted a new meter X years ago and replaced the original cabling.
One other thing the single black cable coming out of the bottom of the ELD goes under the floorboards and is attached to a steel rod which has been pushed into the ground. The green and yellow cable goes to the consumer unit. Is that the house earth and is that standard in all houses?
Any information much appreciated, thanks, Dave.
