Electrical socket circuits using junction boxes
20 Jan 2012
Norwich
My electrical power sockets have been wired with grey twin and earth 2.5mm via 30 amp junction boxes. Who did this; unknown.
The single 2.5mm grey twin and earth wiring originates from the consumer box with RCDs then runs to the first junction box; off this is a single grey twin and earth 2.5mm to a power socket below. As the cable continues from this junction box to the next junction box; again a single 2.5mm cable supplies the next power socket below. In total there are 2no single, 4no double sockets off this single supply cable.
Question:
What is this circuit called; it is not a standard ring circuit where cable runs from main supply to socket; then socket to main supply to next socket returing to the consumer box; allowing current to flow either way around the circuit ?
Question:
The wiring has presented no problems in the last twenty years.
Are there any problems with this type of circuit wiring ?
Question:
This wiring circuit appears to end with the last junction box down to the last power socket below.
Any comments ?
It is called a radial circuit and as long as the protective device is rated either 16 or 20 amps then there should be no problem with the set-up as it is a standard design (albeit unecessary junction boxes if you can loop in and out of the sockets)
Thanks for the input; all sorted and tested now job done.
