Hello,
I've got the dreaded Ecotech F.75 error on the Vaillant boiler in the house which I only bought 3 weeks ago. As far as I can tell, there are no leaks anywhere, but each time I top up the system after a few hours the pressure has dropped again - there doesn't seem to be any coming out of the pressure relief pipe, so where could the water be going?
I've read that this can be a problem with the expansion vessel needing to be "topped up", and/or a faulty pressure sensor.
The digital pressure reading says 2.1bar, regardless of whether there is water in the system or not, so I'm thinking that the pressure sensor is faulty?
If there was a leak, but the pressure sensor itself was fine, would that present itself as a F.22 rather than as a F.75?
Any help would be much appreciated.
Thanks,
Ackoman
Thanks,
Ackoman
