Well i googled that ... https://www.google.co.uk/search?q=F...firefox-b&gfe_rd=cr&ei=8ACZV-3oBMjU8gez1b64BA and didn't see any, or am i missing it?
So i tried Amazon, since it has everything & threw in "F to belling lee" which didn't turn up anything either.
So i threw the word coax in there also https://www.google.co.uk/search?q=F...firefox-b&gfe_rd=cr&ei=rAGZV5vUOsjU8gez1b64BA to see if this would throw up a result of the correct cable to buy & i didn't see it there either.
I'd rather not have to call an aerial installer out just to hand over a 10mtr cable at a cost of £nameyerprice. Sorry to be a PITA but are you able to provide a link of the correct thing? Sorry about this.
I'd like to point out that RG59 cable is fine for CCTV but really bad for aerial and dish connections, since the cable is only specified up to 50 MHz !https://www.amazon.co.uk/RG59-Type-Satellite-Coaxial-Cable/dp/B0035FCQHM
Should look like that
I just used an old image and hosted it last night. I should have added a note that all you needed was the top lead. It was late and I was doing some other stuff at the same time so not really paying attention.But anyway, I don't get why Lucid said I need "AND one of these". I thought the first item (which I've ordered) would've done just fine on its own?
So why doesn't it?
And Lucid already warned about using such cable.
Also, do you really want to buy via a bookseller that pays hardly any UK tax and provides zero technical support? I can tell you from personal experience that their response to a problem is "send it back for a refund".
In fact RG 59 is perfectly OK for short lengths. Virgin Media use internally on their setups and that is up to 800MHz. The problem is that some so called RG59'is not up to spec.
https://en.m.wikipedia.org/wiki/RG-59
I guarantee that VM don't buy it from the Amazon book store. They will have carried out a cost-benefit analysis based on hundreds of thousands of installations where 10p saved on each one adds up to a significant total amount. They will be using cable, which they have tested at the frequencies that they use. They will be able to adjust the gain and the frequency slope to compensate for losses. Joe average can't do this at home; he has neither the knowledge nor the equipment.As I said Virgin Media use it internally at UHF with no problems.
