Whilst doing some minor kitchen DIY in a house we've just purchase I've noticed the oven is on a plug behind a cupboard.
We don't have the manual for the oven but I believe it is an Electrolux EOC65140X (based on google image searching).
An online manual (p55) for this oven suggests a 15amp fuse should be fitted and 2.5mm2 cable. Forgive my naivety but I thought UK plugs were 13amp maximum - so a little curious about this installation.
Unfortunately I can't get easy access to the plug to check the fuse due to how it is fitted.
No power rating is listed in the manual, but from my very basic calculation (using the 15amp requirement) I work out the power of the oven could be up to 3600 watts. Looking online at replacement parts - the fan element in 2400 watts and the bottom element 1000 watts, the manual suggests these can be used combined so I guess should allow for 3400 watts, which seems to correlate nicely with the 15amp requirement.
The fan oven seems to work fine when I quickly tested the oven works, but I haven't tested the combined setting, and now hesitant to do so!...
So, my questions are:
1.
If I try to use the combined setting and only a 13amp fuse is fitted I guess the electrics should trip due to overloading a 13amp fuse? (as 3400w and 230/240v would result in 14+ amps being required)
2.
If the power does trip, is it safe to assume a 13amp fuse is fitted?
3.
Or, could something else happen? (i.e. it doesn't trip and causes an overheating / fire risk?)
4.
If the combined function works okay, is is safe to assume a 15amp fuse is fitted?
5.
If it turns out to be 13amps only - would it still be safe to use either heating element separately until I get this sorted as independently they are 2400W and 1000W ? (i.e. if I'm really not sure about this can I use the oven or grill separately and safely?)
Any help on this much appreciated!
1.
2.
3.
4.
5.
