Hi Quick Question, I have just replaced some cheap plug sockets with some new MK ones, straight forward enough, turned off the fuse to the socket ring and changed them, but while I was changing them the RCD tripped, reset it but it tripped again (not straight away), reset it and it was then OK.
Is there a problem or a reason this happened, I have two other socket rings which I didn't switch off.
