I've started to take down the plaster and plasterboard in what will eventually be our new bathroom. I'm glad I did as structurally some of it is shocking. The batons that go into the brick are loose and it's all a bit of a mess.
The plan (once the electrician has been) is to put new batons up and then drywall.
Regarding the huge gaps at both the top and bottom of the wall. Is this anything to be concerned with? Should I look to cover these gaps with the drywall once it's installed?
I'm concerned I've bitten off a little more than I can chew but I'm determined not to be phased by these holes and crevices (and the spiders) .
I've attached some pictures which hopefully will help.
David
David
