- Joined
- 11 Dec 2007
- Messages
- 404
- Reaction score
- 3
- Country
Looks like that just may well be the one!Is this what you are asking? Best way to join or extend a coaxial cable:
http://www.satcure.co.uk/tech/extend_cable.htm
Thanks (again)
That'll be for the differences between threaded & compressed right?
I'm not overly fussed about the colour. That'd be my wifes areaIs it the type and colour that you want?
If it is, then, yes.
I see that it's twin cable. Do you need twin? Do you prefer it to two singles? Did you choose WF100 for minimum signal loss, instead of WF65, which is thinner and more flexible?
If it is that stuff then would you opt for the twist-on or compression connector & why would you choose said one?
We are going to have to disagree on this, unless you can direct me to your peer-reviewed test results. (I have never found any test measurements comparing the two types.)Compression every time. They have better matching (less return loss) and are more reliable.
Correctly chosen and correctly fitted twist-on types will never unscrew without considerable force being necessary.They don't tend to unscrew off the cable as you fit it to your sky box either.
I grant you they are not "engineers" but the reasons that Sky issue twist-on connectors are that:Cable companies use them because they are the best. Sky installers use twist on types because they are not engineers.
1. They work adequately and reliably.
2. They are cheap.
3. They need no special tools.
Who is "we?" Just ask any RF professional.
