Hi all,
My brother has moved in to a new house which has a gravity fed central heating and hot water system. There is a hot water cylinder in first floor airing cupboard and hot water and central heating header tanks in the loft.
His current shower is a standard mixer valve (non-thermostatic from what I can tell). It's fed with hot water via 15mm pipe taken from a tap off the 22mm hot water feed from the top of the hot water cylinder. The cold is fed from a 15mm tap off the cold water feed to the hot water system (gravity side, not mains).
I understand that I can upgrade this installation to a power shower by installing a dual impeller positive head pump. I plan to fit this in the loft by cutting the hot and cold supply pipes to the shower and plumbing in the pump.
I had read that the hot water supply for a power shower pump should come from dedicated tap lower down the hot water cylinder. The explanation for this is to prevent air bubbles at the top of the tank getting in to the pump, reducing it's life. Is this strictly required? If so, what would be required to add a second tap off point to the tank?
Any other general advice would be greatly appreciated.
Matt.
Matt.
