passing cables through layers of insulation (help please)
30 Mar 2015
Hi All,
I set out my downlight cables before plastering. All laid correctly with pictures and a measurement plan.
but...
after the ceiling was plastered we changed our mind on the positioning of the lights. I've located the feed and switch cable but now need to thread a new cable to the new holes for the spotlights.
problem: Cant get in loft as its too shallow and when I push cable (also tried a hep pipe) it bends against the insulation. The distance between each hole is around 1.25 metres.
any advice will be greatly received.
nooooo. Don't say that :(
I did plan impeccably. The plan changed...
Yea was gonna suggest drilling out the holes for the lights, then using rods to push the cables through.
Bet I could get in your loft
If it's only lighting you may not need to upgrade the cables - if they pass through insulation.
You'll need to check the circuit loading and do your cable calculations again. :rolleyes:
I marvel at some of the places I used to wriggle into.
Not happening now!!!
:fatstiffjointedman:
Perhaps I should have said "in my professional career"...
Hang on, that sounds like "confessions of a sparkie"...
When I went round to ladies houses, I used to wriggle into their holes.
Oh, dear. This is getting worse.
Customers used to pay me for wriggling around in their holes.
No, no, no...
I used to pride myself at getting into tight places.
That's not right either, is it?
Hold on...
When I was working, I used to be limber enough to...........oh FORGET IT!
