Light switch wiring help!! (moved from GD)
No definitely didnt mean that.
I mean, would it be possible to run a new wire from the light. Put a single surface mounted light switch in it and then have it plugged in out the way into a spare plug socket behind my fridge?
Like my diagram below. Apologies I'm no art major...
Would running a fused spur from the socket behind fridge, and then onto the light, be an option for the OP, assuming said socket is part of the ring main and not already a spur?? :unsure:
EDIT
Seeing KP's last post, I'm pretty sure that is a feasible solution....I had that set up for my outside lights back in the UK.
Yes it would be possible to have a in-line switch between a socket and the outside lights.
You would need to down fuse in the plug to something between 1-5amp
Under current Electrical regulations you have to be qualified and have the Electrics Certificated for fitting an outside light, (an unqualified person can replace an outside light but not install one)
Suggest its best if you get a qualified electrician in and do the job properly.
I would disagree that the current electrical regulations, require you to have any qualifications!
They may suggest that you are skilled electrically but no mention of quals required.
But agree that this is a task should be undertaken by someone that does have the knowledge and skill, which by evidence the OP does not!
Put a th
If putting it on a plug he just needs to be competant.
Did you mean because of the Building Regulations Notification Requirements?
If yes, then that is no longer the case in England.
All homeowners must be able to prove that electrical installation meets with part P or they are committing an offence ,
by using a registered electrician they will arrange for the home owner to receive a certificate that the work confirms that it meets regulations.
The original poster appears to have absolutely no idea of how to wire a basic light switch.
Yes, that's true and correct.
I just thought you might be be referring to notification of outside lighting which used to be the case.
But there is nothing that actually states that part p compliance and certification is required from a qualified person.
I know obliviously they must have some skill and knowledge to be able to perform these tasks safely and correctly, but qualification are not a requirement.
It may just be confusing wording, but to be accurate and clarify:
Part P of the Building Regulations is The Law and therefore everyone must comply with it.
There is no such thing as Part P certification. Certification may be issued by anyone.
Anyone may do electrical work, but:
Agreed.
Agreed.
Whoever issues the certificate must be registered and qualified, You state anyone can issue the certificate,
Its a bit like saying anyone can issue a MOT certificate for their car, regardless of knowledge.
I would suggest to a DIY`er putting in an outside light it would be easier to fit a Solar Power light, these are very cheap these days, operate remotely no need for any switching, come in many modern designs and cheap to run, coloured LED`s if one wants, cheapy outlets do them , i.e lidl, Pound Shops etc.
That is not the case.
Anyone may do the work and may issue a certificate.
You will note I correctly use 'may' (i.e. are allowed to), whether they 'can' (i.e. have the knowledge) is another matter.
They 'may'.
That's not the same. MoT inspectors are licensed (if that is the right word).
Electricians are not.
In order to do notifiable work (as per the B.R.) without notifying the L.A in advance they have to be registered with a self-certification scheme. This does not relate to issuing electrical certificates.
Is that where you are confusing certification?
They would be better named Self-notifying schemes.
The only notifiable work now is:
(a)the installation of a new circuit; It is up to you to define new.
(b)the replacement of a consumer unit; It is up to you to define replacement.
(c)any addition or alteration to existing circuits in a special location.
A special location being within the zones of a bathroom etc. - wet areas.
What do you mean by a DIYer?
I presume you mean someone who does not know how to do it.
If someone does know how to do it, they won't be here asking.
You may think electrical work should be illegal except for the qualified but it isn't.
Do you think this forum should not be allowed or does it help?
