Oven tripping rcd.
24 Sep 2011
Devon
As per title,I have a double oven,the lower fan oven trips the rcd,I've replaced the element,still the same fault,although the element I used for replacement had been in the garage for about two yrs,they don't have a shelf life do they?
I can turn the oven on to just the first setting which is just the light but when I turn it up to call for heat with in 5 to 10 secs it trips.
Oven is a Hotpoint DY46X.
Thanks in advance.
Not a 'shelf life' as such, as far as I know, but if it's been in a garage for two years, moisture may well have got into it, in which case the trips would probably stop if you could dry it out. The ideal would be to remove the new element and 'cook' it for a bit in some other oven, if you have one, otherwise by some other method.
Thanks for the reply,I can use the top oven,so will try that.
I tried that to no avail,so am waiting on a delivery of a new one.
You sure it's not tripping when the fan cuts in. I doubt a new unused element gives the same fault as the existing.
Dis-prove the switch by disconnecting (and isolating) the wires at the fan, and see if it still trips. I had similar occasional 'oven trips' which turned out to be wires needing extra insulating.
Hi Tony long time no see,yep definitely the element,new one arrived this morning and fitted,heated the oven up to temp and no trip.
Thanks to all.
I had the same issue with an oven, switched it off at the mains and stuck a fan heater in it for 1/2 hour sorted !
Regards,
DS
Thanks to all.
Well I honestly didn't expect that to be the cause Barrie.
Anyway I'm good thanks. And you, did you get sorted alright?
