Armoured Cable Outside Socket
7 Oct 2004
I have a normal plug socket in shed that is connected by Armoured cable. I am planning on removing the shed and then terminating the the cable somewhere outside. My first thought was to wire it into an outside socket. However do I need a specific type of socket to accept the Armoured cable glands? Do I need the special glands and are they easy to fit. Or is there a simpler way of terminating the cable?
Hopefully that makes sense
Many thanks
I think wether or not it is notifiable depends where you live, which country are you in?
All the wiring is already done all I am doing is replacing the socket
Even in Wales, literally replacing the socket (in the same location) wouldn't be notifiable - but there might be some debate about 'relocating' a socket in the manner you intend.
However, what matters to you is that in England, the work you want to do would certainly not be notifiable.
SWA can be glanded/terminated satisfactorily in many 'outside' sockets, but if you are not used to working with SWA, it might well be worth leaving the work for someone who is.
