In our new house we have two doors upstairs that are narrower than all the others. The normal door openings are approx 790mm wide. The toilet and bathroom doors are narrower, at 680mm. These sizes are from memory so may not be totally accurate. However, the bathroom door doesnt bother me, as it is being boarded up. The wall between toilet and bathroom will be knocked down and we will use the toilet door to access the room.
The door sits at the end of a thermalite block wall, so one edge is against an external brick wall. The more i dig into the door frames the more I think this isn't going to be a worthwhile cause and I should put up with the narrow door. But then will I get the new bath in?
Anyway, pictures . . .
this wall will be removed. The frame you see, I want to extend to the left.
Above all the door lining sides is an upright of timber that appears to be embedded in the wall.
What trade could do this widening for me? Should I get a builder in? Or a joiner?
Also, another issue, I was planning to remove all the door linings and renew, but they are massive chunks of wood, probably due to holding up the walls above them, so I won't be doing this. However, i would like to level off the tops! A couple of them are an inch out! What is the best way to do this?
I thought about maybe using some new door lining and adding it into the existing frames, but this would make the frames at least 1.5inch shorter. Would this be acceptable?
