Hi all,
I know there are lots of threads out there on this however I have a rather specific situation and would appreciate any advice that can be offered..!
We are currently renovating and extending an old cottage (first written record of it is in 1770 but it is probably older). It is not listed but we are doing everything we can to be sympathetic to its heritage etc... Over the years it has had a number of inappropriate works that we are currently trying to resolve so our works are quite extensive... Part of these works involved removing a concrete slab and we are putting limecrete (breathable) base back in. When we are done the house will consist of:
Downstairs (low ceilings)
Due to the nature of the house it's thermal performance varies enormously from room to room, for example the kitchen/diner will be in the new extension and conform to current building regs whilst the lounge has solid walls and the hallway wall is in one place only a single skin brick wall...
Downstairs we are having underfloor heating throughout, the intention is that each zone will have a thermostat which will enable the system to react to the different circumstances in each area, maintaining a steady temperature through the house. This is the standard system utilised for (wet) underfloor heating systems.
Upstairs there will be radiators (probably column radiators from https://www.columnrads.co.uk/) and there is an ongoing debate over how to plumb and then control this system. Our plumber would like to install a normal system with a thermostat controlling the "upstairs zone" and TRV's on the rads. The thermostat would go on the landing. I have concerns over this system because:
I have suggested the upstairs radiators are controlled by a manifold and each room has a thermostat (or digital thermometer) controlling the manifold. Which system would control this I don't know but am researching Fibaro, Honeywell Evohome, the 12v heatmister system with control pad, etc...
I like the 12v heatmister system as it could control a manifold for the upstairs rads perfectly but would prefer it if the thermostats in each room were "dumb" and you couldn't alter settings from them...
I fear I am overthinking this all but if anyone has any thoughts they would be appreciated..!
First fix is due in a few weeks so I need to make a decision asap...
- Kitchen/Diner
- Utility
- Large Hall
- Study
- Lounge
- 4 x Bedrooms
- Ensuite
- Family bathroom
- small landing area
- the upstairs walls are similar to the downstairs and range from current buildings regs compliant walls to a 100mm timber frame tile hung wall
- TRV's don't look good on the column rads in my opinion
- the landing will be quite warm due to the heat rising from the large hallway below which will mean the thermostat rarely triggers.
- Due to the nature of the house we want to minimise gadgets on show, we also want controls out of sight or lockable so children/visitors cannot alter the settings easily.
