Vaillant+ecotec+plus 832 heating not warming fast
7 Oct 2016
hi
My boiler works fine for hearing water, but I'm having some problems with heating. The water flow through temp is set @ 60c but when I change the thermostat to a higher temperature it will only ever go to about 40c or so the n go less than this. My radiators get warm but the temperature never reaches what I set in the thermostat. I've tried setting it at 25c but it still just heats to about 18/19c then the flow temp either stays constant at a low40ish or drops again. Does anyone have any idea why this is happening?? Thanks
Is the gas supply to the boiler sufficient? If the gas pipe is undersized th boiler will struggle to run at full rate and get the flow temp to max
If the gas supply is undersized do you think the hot water would be ok on an 8 series Bunny?
