- Joined
- 2 Nov 2015
- Messages
- 71
- Reaction score
- 2
- Country
For fitting a oil boiler to a wall as a new installation, what is the best procedure for drilling the flue hole?.
Basically, as per the instructions the flue has to be at a slightly upwards angle so that condensate can roll back. However I'm just wondering how big a drill bit to use for the core drill.. Here are my questions:
The hole is going to be through a cavity wall.
JH
- So given the flue diameter is 100mm, what is the appropriate size core drill bit to use (diameter wise)?
- How do you determine the angle?? is it just by tilting the drill slightly or is there a more accurate procedure?
JH
