Afternoon all.
Looking at surface mounting a loop in box which will in turn have a dome/spout cover installed to route lighting circuit out of a wall (existing wall light location).
One thing that is unclear to me, apologies if this is a super rookie question, but how would you fix this to the wall? The only holes in the rear of the boxes I'm seeing are the 20mm cable entry and typically an M4 threaded hole for earthing.
Also, with the earth connection, what length of screw would you normally use? It only needs to firmly hold a crimp lug in place...
Appreciate any comments you may have.
