I did anticipate using a very old mains powered Klaxon ET-H as a door bell, but it's so frighteningly loud I decided against it. The neighbours probably wouldn't have liked it much either...
Join the club - most of us have done it, more than oncePost deleted. sorry i quoted my own post and so deleted now, I was meant to edit it.
Probably not, since that would reduce the percentage of posts that had received Thanks or LikesTrying to bump up your post count?!![]()
Capacitor symbols now corrected. However, I'm not sure I know the circuit symbol for solar flares...Seems all OK, perhaps you may want to show the capacitor symbol with one side not infilled, just the outline to represent positive plate of the capacitor, for an LED that does not draw more than about 20- 50mA current a value of 22uF would suffice, rated at approx 16 to 25v , avoid using too high a value, as this may produce some arcing across bell contacts and this could result in switch contacts burning eventually causing early failure, a 22uf would stop simmering effect of half wave DC . On a full wave you may not even need it and avoid it at all cost because if your ac off load voltage is 16v then the final voltage after rectifying and adding that smoothing capacitor will raise it by 1.414, so if you multiply 16 x 1.414, you will get approx 23Volts! with LED connected across it may drop a bit to like 18V, it is still way above the rated value of the LED at 12v. With half wave your average value of DC voltage will be a lot less than 23v it will probably be around 12 - 14v dc. (all depends of course what current the LED is pulling through. It can only be determined by actual circuit and measuring it. Theory is one thing, practice is another.
Theoretically I could send a rocket to moon, but practically I know it will probably land somewhere in Timbuktoo. This is why most missions to Moon and Mars fail the first few times because even the most advanced experts get it wrong as calculations and formulas rarely reflect reality. Effects of solar flares, which no one can predict can deflect intended route.
I do not think you need any smoothing cap on a full wave rectification for an LED.
Indeed, you see now, how hard it is to even earn a single "Thanks" I still haven't earned one yet on this thread, yet you see others how they give their mates fake thanks by making sarcastic remarks and insults. but there you go the world is not perfectly round, there are some flat spots.Probably not, since that would reduce the percentage of posts that had received Thanks or Likes
