- Joined
- 2 Jan 2017
- Messages
- 6
- Reaction score
- 0
- Country
Hi All,
I'm new here so please be gentle
Ok so here goes - I moved into a new house back in June and was told that the next to last owner lived here with her nephew and had opted to have a vented cylinder installed in order for there to be no contention for hot water when both showers in the house were used at the same time.
The cylinder is backed by a more recently installed combi boiler. I'm not sure what the combi was used to replace, but the resulting setup is now :
Vaillant ecoTEC plus 630
Santon PP2108
Since recently having smart electricity meters installed I've noticed that the vented cylinder is kicking in fairly often, drawing about 3kW for anything from a few seconds to over a couple of minutes.
Is this normal?
Something else I've noticed is that the en suite shower loses pressure when the bath in the same room is being filled, and also when the water for the kitchen sink is run. I thought that the vented cylinder should provide sufficient flow to avoid this?
The Vaillant is set to hear water to 75 degrees, and seems to use a fair bit of gas. In terms of reducing our bills is there anything I can look out for, as according to our supplier we are using more than average and I was under the impression that this kind of setup should be really efficient after the initial outlay!?
Thanks in advance
Santon PP2108
Is this normal?
Thanks in advance
