Texecom Shock Sensor Sensitivity
1 Sep 2015
I'm trying to configure a Texecom Shock Sensor, but I'm having a bit of a nightmare.
In the guide, it says a firm tap, so it hit the window with my fist to simulate something like a football hitting it.
If I am on low range but high sensitivity, I get a green light which indicates its not sensitive enough.
The only option I am left with is to go to high range, however at low sensitivity I get a green, and then red LED.
Does anyone have any suggestions as to what sensitivity I should aim for?
I did try to crank it up until I got orange, and then dialed it down until a knock became a red, but again I was right at the bottom of the sensitivity range.
Any suggestions?
You can not set up a shock sensor by hitting the window/door with your fist ?
You need to use a hard object ?
Use the handle of a screwdriver,start with a lite tap on the frame not next too the sensor ?
These devices react to a sharp vibration,not a thud with your fist.
Even my wife laughed when I read that to her :LOL:
but you will need to replace the glass afterwards
Tbh shock sensors are a pain in arse, cant stand the things.... and thats any brand.
Well tapping with a screw driver, knuckles or fist makes no difference! They all report the same damn thing
Post photo of the shock sensor fitted to your window
Post photo of wiring shock sensor
Possible not set up correct
It's a wireless shock sensor so no wiring.
It's a 3 pane window, the device is screwed through the screw holes into the window frame above the middle window
For reference its a Texecom, the GBC-0001 I think it is
