- Joined
- 5 Jan 2017
- Messages
- 13
- Reaction score
- 0
- Country
I have a grasslin tower chron QE2 and a mechanical Honeywell thermostat. Is it easy to fit the nest
I have posted some photos on line. I am going to fit it on SaturdayShould be ok with a Nest but need a bit more info about the system.
Is there a 3 port valve ( looks likely from the wiring ) and do you have a room thermostat?
Some pictures of the room thermostat wiring and the internals of the main wiring centre would be useful.
Thank you I am going to fit it on SaturdayDisconnect the room stat, it looks like its the grey wire in pin 10 and one of the browns in pin 9
Move the white wire to the 3 port valve to pin 9
Room stat is then bypassed
You will also want to remove the neutral and earth going to the old room stat as well. Follow the brown and grey wires back and you'll be able to find which black and green/yellow one it is. Once finished tape it up or cut it off so it can't touch anything and become live.
You could use those wires to power the Nest stat if you're putting it in the same place as your wired stat, and you have two spare cores between the heat link and the wiring centre, I didn't, so I've just got my Nest stat plugged in.
