Plyboarding floorboards
5 Feb 2007
Liverpool
I need to plyboard over my landing floor boards before I get a new carpet. The floor boards are not terrible but there is a few cap in between where they got ook u for central heating. Because of this the carpert went abit wavey. What size ply suits. Is 4mm ok or will I need 9mm
If the T&G boards are firmly fixed and non-squeaking then why not use hardboard and a quality underlay?
I've always used hardboard because it's cheap and easy; I use 4x2's and use ring nails every 150mm, and never have any problems, but I came across an interesting thread recently that advocated 6mm ply and feather edge levelling compound. As long as there isn't too much difference in the height of the existing floorboards, then I'd use hardboard, but if the floors very uneven, then I'd go for 10mm ply.
And if you use hardboard, then the smooth surface goes underneath.
I don't think strength is the issue though just the unevenness of the boards. Hardboard and a decent underlay. watch out for pipes when nailing
Wouldn't it be quicker easier and cheaper just to replace the few bad boards or fill the gaps with stripwood? The board themselves are not uneven, right?
Would be alot easier to just go over save lifting boards up. Stripwood would not work as the floorboards snapped in even places. I would have to cut all original floorboards to get a straight egdes then add strips.
That's done a lot in commercial jobs - a bit belt and braces but the flooring fitters seem to like it. Depending on spec we either screw the stuff (collated screw gun) or taple it (gas stapler)
OP,
You are going with carpet on a landing - top step riser height, and possible nosing difficulties might come from raising the FFL.
Door thresholds to bathroom and bedrooms might also be affected.
All you are looking for is something to level out the boards, and pinned down hardboard will do the trick for an underlayment - as in my post above.
Dont give yourself problems where its unnecessary - keep it simple, and have the carpet well tacked and stretched.
