Afternoon all.
I am looking to install a 9.5kw electric shower in one of the bedrooms I will be running a separate 30m, 10mm twin and earth cable from the circuit board to the shower. The cable will run the majority of the way through the loft and a cavity wall, however there will be a 9 to 10 foot section that i will have to run inside a cupboard on the outside of the plaster. If I was to encase the cable in plastic trunking for that 9 to 10 section, would this be acceptable for the electrician to pass it? Also, I am just looking to tack the cable to the top of the joists in the corner of the loft, will this also be acceptable?
Thanks in advance.
Thanks in advance.
