Turning electric socket into a switch for another socket
1 Feb 2017
I have a single socket high up on a wall (most likely for a tv to plug into). The floor above this is the attic.
I would like to ceiling mount a projector but dont want cable/leads to be seen.
Am I able to:
replace the socket in the wall with a switched fused connection unit, put a 13A junction box up in the attic to bridge the ring and also from this connect the switched fused connection unit and a socket in the attic, so that the switch in the wall turns off power to the socket above the ceiling?
Jonny
Yes the socket is connected and live - it is part of the main ring so has 2 cables feeding it from the attic feeding it ?
Am I able to:
Yes.
If you want. Why not a socket?
to bridge the ring
Don't understand that bit.
Socket FCU >>>> socket - to plug in projector.
What could be simpler.
so FCU will have two cables (ie the ring), then on one of these cables if I add a socket - when the FCU is off, will that not break the entire ring and turn all sockets off?
I think I get what you want to do now. So, the ring cables going in/out of the socket will be changed to supply and load in the FCU ? In the loft you will cut into those two cables and 1 will now go into the junction box maintaining the ring and extending to the FCU) and the other to a double socket? Do you really need an FCU? If not then just leave the socket on the wall and add a double socket on the ring in the loft.
No. He can just spur from the new FCU which is replacing a socket.
It will not affect the ring - if you do it properly.
I assumed he wouldn't be able to feed a fresh cable to the socket/FCU and it was likely plastered in but probably should of asked :confused:
Oh. If he can't do that then he won't be able to do what he wants.
You put the ring cables together in the FCU (as they are in the socket) and a new cable from the load side,
If there's no real reason to needing a FCU in the room, I would leave the switch as it is and add a double socket in the loft like EFL said. If you need remote power control then use a smart socket or energy saver extension etc...
Yes.
Double pole switch>>socket>projector.
You don't need or desire 2 fuses in line (one in the FCU and one in the plug).
Why not either leave the socket, and spur from it, or replace it with a JB, and spur from it.
I cannot for the life of me think why a switch is needed.
