I have a 1910 London house covered side and back with limewash, then masonry paint on top, it was like this when we bought it and have been trying to figure out how to remove it ever since. The masonry paint is fairly loose and peeling in most areas (common for paint over limewash).
Chemical Paint strippers or steam (Doff) will lift the masonry paint without much problem. The question is how to remove the limewash from the bricks. These are London yellow stocks. Acid has been tried with little success but from memory I'm not sure which acid it was.
I've tried sanding the face on a test area (it's a outside cupboard or lean-to that will probably end up internal via an extension in the future). This was done with a speed controlled 7" polisher with a 30 & 60 grit ribbed silicon carbide disc. Inevitably, this takes some of the brick surface with it, leaving the surface looking quite 'open', notably small air pockets in the bricks become visible. I've seen this brick 'look' on many buildings around london which presumably have had a similar treatment either via blasting or sanding. While I've seen it done elsewhere I'm still unsure this is the right approach.
I've read about the TORC wet blasting system as being a possible solution, however when sanding the bricks with a disc, it was apparent that the limewash is harder than the yellow bricks themselves. This makes me think that any kind of blasting would be inappropriate as once it had gone through the limewash in one spot, it would eat into the bricks quicker than it would take off neighbouring limewash?
I've uploaded a photo of the limewashed bricks, and the sample area.
