Alarm bell box cover
23 Dec 2007
Yorkshire
I decided to remove the bell box cover on the old Wickes house alarm as the siren was not sounding on activation. Found a wire had corroded so repaired it and all good. However, being a clumsy oaf, I managed to stand on the cover which was brittle with age and therefore shattered. Have searched ebay for a replacement but no joy. The cover I need is the old 5 straight sided one with vents at either side, just wondering if anyone knows a source?
If its a hardwired system you can most likely fit any new external siren. A new siren increases the deterrent value anyway so its always good to replace at 10years max IMO.
If
If your control is a wickes panel look above,you can replace bell box with any make or model.As engineer says a new box would let people know that alarm is new.
Pyronix delta bell are good ,below £20
Replace the whole bell with a Pyronix Deltabell, as Sparkymarka suggests. (He may be fairly local to you and could help if you can't manage it by yourself...)
Have decided as advised to go with a Pyronix Deltabell. I have also managed to find the wiring instructions online so I should be ok with the fitting but have no doubt that, should I have any problems, some one on this forum will help me out. Thanks for all replies.
Update. Managed to source a new cover for my old Wickes bellbox. I would now like to fix a 12v led to the cover to show that it is a working alarm (as it's old). I would prefer this led to be lit constantly so which 2 connections should I use? The bellbox has RET- ,SW ,BELL- ,BELL+ ,V+ and V- .
Hoping someone can help.
Hi, long shot, but anyone know where I can get one of these old vented boxes from .
Searching online but no luck so far.
Just need the old vented, plastic box
liam
9FD871B3-8B5E-4543-9D3C-6AE70D040E92.png To be honest at that price ,your not far off a modern up to date new bellbox complete ….
View attachment 261380 To be honest at that price ,your not far off a modern up to date new bellbox complete ….
Many thanks sparkymarka,
Tbh, it's just as a bothcit.
I may just leave it , if I can't get that yellow one, or just take the old, unworking lot off the wall, as having one 1-in bits up there may get the interest of burglars.
Thanks again
