I'm having the house re-wired at the moment. A friend of mine who is a fully qualified electrician has offered to come in for a few hours and fit a new CU for me (Hager Design 30, fully loaded with RCBO's) and he knows I'm fairly competent, so am good to do most of the donkey work (chase walls, run cables) with him to finish it up.
Anyhow I've just ran a completely new upstairs ring and have left the tails under the floorboards of the upstairs landing.
I've already pestered my mate enough with questions about this, so I was hoping I could figure this one out for myself (with maybe a little help from people on the forum!)
so if you look at the side view of the house, the consumer unit is going under the stairs, and the 2.5mm T&E tails are under the floor boards on the first floor. Obviously the tails are not "directly" above the current CU (as indicated by the second "top-down" picture) as the cu is on the wall whereas the tails are under the landing.
So my question is, what's the best route to get the tails back down to the CU? I know I can't go directly through the stairs as that's part of the safe zone.
So do I go under the bath in the bathroom, then down into the kitchen? This is not ideal as it will mean ripping the kitchen apart?
Can I go outside the property and down the outside wall, then back in again?
Should I go across to the box room, then go straight down that wall? The problem with this is that I'd then need to go horizontal along the wall (The ground floor is solid concrete).
Any suggestions?
Any suggestions?
