I'm doing some work in the loft and need to relocate or get rid of the cisterns for hot water and central heating. Hopefully converting the central heating to be a sealed system won't be a problem, the boiler can handle it, and I'll wet pressure test it when I alter some pipework next month to see if it's up to it first.
I've been thinking of an unvented cylinder for a while when the current one goes bang to get better pressure on the hot side of things, but now I'm thinking why not just get one fitted now to kill two birds with one stone and ditch the loft tank. Ideally I would like to locate the new cylinder in the garage next to the boiler, so no issues with floor loading or leaks, and it will free up the airing cupboard upstairs giving us some much needed storage space.
I've got absolutely no plans on attempting to fit an unvented cylinder myself as I understand the dangers of one fitted incorrectly. I've been doing some reading and I've just got a few questions to hopefully decide whether I go for it or not...
1- Can the pressure relief valve be piped to discharge onto the path directly outside the garage, or does it have to go into a proper drain? It'd be possible for it to go through the wall at low level to minimise the risk of injury etc. There's a drain pipe in the path but no gulley, I could put one in if required but don't want to start digging holes if I don't have to.
2- My house is a 4 bed detached, 1 main bathroom and an en suite with a shower, from what I've read a 210 litre cylinder is roughly what's needed, but my existing cylinder looks tiny in comparison (see below). Currently the hot water is programmed on for an hour in the morning and an hour at night which is more than enough for what we use. Do I really need a 210 litre, will a smaller one be cheaper to run? I'm not worried about the purchase price difference as it's not that much really.
3- In the en suite I've currently got a Triton thermostatic power shower (has hot and cold feed, doesn't heat its own water). It'd be a major event to get rid of this and revert to a normal shower, is it likely to run properly whilst under mains (ish) pressure hot and cold water? I'm thinking of fitting a steam shower in the future, but not quite ready for it yet as it'd involve smashing the en suite to pieces.
Thanks in advance for any advice...
