You won't get a certificate for a loft area - the presence of too many fibres (insulation) makes it impossible.
You don't turn up with a large piece of material and ask for it to be tested. A small sample is taken, sent off and you will receive a analysis of the sample.
The company have stopped work and say they will not return until I provide a clean air certificate. Is it possible to have the loft air tested for asbestos?
I am an infirm 76 years old pensioner and am not competent to take a sample from the “asbestos” to send in.
Some firms do accept material taken in (including the one above).
Others require the applicant for a test kit in the post have to first confirm in writing that they are trained in taking asbestos samples.
It is only a small piece of loose material and no sense in the expense of the alternative of someone coming out to the property to test it.
I have to take it in.
I have spoken to UKAS about this.
Thanks for help
JamesEB
