When building a blockwork cavity wall, I've seen loads of pics with the solid 100mm concrete block on the outer skin and thermal blocks on the inner skin. My assumption is the 7.3N concrete blocks are better load bearing and the lighter thermal block offer better insulation......
Is there any problem building both skins in the heavier duty concrete blocks? I ask as there will of course be 100mm of cavity insulation, but the solid blocks work out at £1/block and the thermal blocks £1.42/block. This is for a single storey extension.
