At the outset let me say that I am not looking for self help advice: this is clearly a job for a professional.
I have a 250L OSO 20RD unvented cylinder. It has been installed for 15 years. It serves two Bristan thermostatic showers which recently have started to run cold. There is no pressure equalising valve between the cylinder and the two adjacent back-to-back showers.
I have re-charged the cylinder air gap and the shower will run hot for about 2 minutes or until someone turns on a hot tap somewhere else in the house. When, say, a bath has been run, I can hear the unvented cylinder topping up with cold water for a short period of time after the tap has been turned off. HW flow to the taps (up and downstairs) is good. Cold water supply is via a PRV and a Kinetico HF 2020C water softener.
Could it be the the unvented cylinder valves/filter need checking or cleaning, or should I be looking at something else? Logic, at least to me, would suggest that the problem is falling pressure in the Oso cylinder as hot water is dispensed.
Grateful for any thoughts/advice before I approach a G3 qualified plumber.
