I have recently built a shed and have a 6mm armoured cable running to a consumer unit in the shed.
I now want to add 4 lights, two on the left and two on the right, on a double switch, working individually (left and right) the consumer unit is one end and the switch will be the opposite.
So I basically want to run two cables from the consumer unit, to two lights then on the left and right then to the same double switch.
I have 1.5mm twin and earth. Is it just a case of one cable both sides going in and out of the lights and continuing?
Any advice/diagrams would be hugely appreciated. Many thanks
